Threaded TEE for 9 5/8" casing
Hello, for an experimental setup I need to connect a 6in pipe line to a 9 5/8” casing. I wonder if there is any kind of standard piece that I could use (or modify to be used) as a tee.
JR
JR
RE: Threaded TEE for 9 5/8" casing
The CWP is the pressure you expect to be running through the pipes
You can then add or cut threads or if it is to be permanent weld
