SE Installation problem
While trying to install SE 15 on a machine I get a message that says a version of SE is on the system and I need to uninstall it first.  There is no and never has been SE on the machine.  Any suggestions
RE: SE Installation problem
Check that there is no Solid Edge listed in Config Panel/Add or Remove Programs. (If there is remove it)
Then run the executable under SptTools/SECleanup on your CD prior to installation.
Fred
Thanks for the quick response, however it didn't do the trick.  I'm still getting the same message.  I did notice that there is an MSICleanup utility but there are only ones for win 9x and NT, we are running 2000 Pro.  Any other sugestions?
Please check the entries in your system registry.
Try registry clean.
I have seen this issue on Win 2000.  The SECleanup.exe utility available on EDS' FTP server has worked beautifully.
