Pressure Relief Valves
I am working on a large concrete tank which will located in an area where the groundwater table is likely to be at or near grade a large portion of the time. I am going to install pressure relief valves in the bottom of the tank to ensure it doesn't float when emptied, but i am having a difficult time locating any definitive design information.
The tanks will be about 6m deep. I have located an old detail showing installation of the valves, but nothing to say how many and what spacing they should be installed.
Does anyone out there have any guidance.
Thanks much
Thanks much
RE: Pressure Relief Valves
Where will the tanks be located? (city, state)
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.
I have been cruising the net looking for some guidance, but as I stated, nothing great yet.
Here is a site for hydrostatic valves that I have used:
http://www.trumbull-mfg.com/hydrostatic.pdf
Some good info, hope this helps.
If the valves actuate frequently - or with a significant pressure buildup - you could erode some of the soils from beneath the crushed rock (loss of ground) which would cause the tank to settle unevenly.
Focht3, we do have the filter designed below the tank, and I plan to dig up that reference just to familarize myself a little more. These valves would be little used, as they are to be in a bioreactor in a wastewater treatment plant.
Thanks to both of you for your input, it has been very helpful,
dutchie
