Pb programing an interface under QNX
hello, I'm currently working on a robot contoled under QNX. I'm making an interface whith PhAB an have a little pb.
I edited the gcc_nto*/Makefile
and added "-Bstatic -l ph -Bdynamic" to the link lines ( LDFLAGS=... and
SDFLAGS=... ) to put PtNumericFloat into the shared library, but it seems I still get pbs whith the PtNumericFloat.
Here is my code :
      /* Y o u r D e s c r i p t i o n */
      /* AppBuilder Photon Code Lib */
      /* Version 2.01 */
      /* Standard headers */
      #include <stdio.h>
      #include <stdlib.h>
      #include <unistd.h>
      #include <string.h>
      /* Local headers */
      #include "ablibs.h"
      #include "abimport.h"
      #include "proto.h"
      PtWidget_t*link_instance;
      PtWidget_t*Nfich;
      PtWidget_t*g[3];
      float *gain[3];
      FILE*file;
      FILE*aff;
      char*nom;
      int
      gains_acquis( PtWidget_t *widget, ApInfo_t *apinfo, PtCallbackInfo_t
*cbinfo )
      int l=0;
      /* eliminate 'unreferenced' warnings */
      widget = widget, apinfo = apinfo, cbinfo = cbinfo;
      link_instance = ApGetInstance(widget);
      Nfich = ApGetWidgetPtr(link_instance,ABN_gains_nom);
      PtGetResource(Nfich, Pt_ARG_TEXT_STRING, &nom,0);
      file = fopen(nom,"r+");
      fseek(file,47*sizeof(float),SEEK_SET);
      g[l++] = ApGetWidgetPtr(link_instance,ABN_gains_kp);
      g[l++] = ApGetWidgetPtr(link_instance,ABN_gains_kd);
      g[l++] = ApGetWidgetPtr(link_instance,ABN_gains_ga);
      //ABN_gains_kp and so are PtNumericFloat
      l=0;
      aff=fopen("affich.txt","w");
      for(l=0;l<3;l++)
      PtGetResource(g[l],Pt_ARG_NUMERIC_VALUE,&gain[l],0);
      fwrite(gain[l],sizeof(float),1,file);
      fprintf(aff,"%f \n",*gain[l]);
      fclose(aff);
      fclose(file);
      return( Pt_CONTINUE );
But when I open affich.txt, I only obtain
0.0000
0.0000
0.0000
whatever I type in the widgets when running the application.
Then I tried something :
      /* Version 2.01 */
      #include <stdio.h>
      #include <stdlib.h>
      #include <unistd.h>
      #include <string.h>
      /* Local headers */
      #include "ablibs.h"
      #include "proto.h"
      PtWidget_t*Nfich;
      PtWidget_t*g[1];
      int *gain[1];
      FILE*file;
      FILE*aff;
      char*nom;
      int
*cbinfo )
      int l=0;
      fseek(file,47*sizeof(int),SEEK_SET);
      g[l++] = ApGetWidgetPtr(link_instance,ABN_gains_test);
      // ABN_gains_test is a PtNumric Integer
      l=0;
      for(l=0;l<1;l++)
      fwrite(gain[l],sizeof(int),1,file);
      fprintf(aff,"%d \n",*gain[l]);
      fclose(aff);
      fclose(file);
I just added a PtNumericInteger in the window, and changed the code to write
this number instead of the three previious ones. Then I obtain an integer
equal to the one I type when running the application.
I don't really need the .txt file, but I'm afraid that the other file
(fwrite(gain[l],sizeof(int),1,file)) won't be written correctly. Is there
another thing to do so that PtNumericFloat would be accepted, or is there a
mistake in my code (sometimes I'm quite lost whith the format in functions)
