Metering valves for low flowrates
I am trying to find metering valves for the injection of liquids at very low flowrates.  I have found SkoFlo valves so far but was wondering if anyone had any other information on where I could find similar type valves.
RE: Metering valves for low flowrates
How low flowrates are you talking about... and what fluid? Neptune Flow Meters have a pretty good range.
Here is the website of the manufacturer we used almost exclusively for bench scale and pilot plant work.  The valves are called “Research Control Valves”.
http://www.badgermeter.com/index.htm
Thanks guys.  I'll check both those out.
Chris Conley: the flowrates are ridiculously low - in the region of say 100 ml/hr!
minty
For your application I suggest:
Swagelok S,M,L or their 31 series. Very low flow coeff.
 www.swageloc.com
Another is:
Hoke Micromite 1600 Series, Cv down to 0.0008
 www.hoke.com
The above listed products have micometer type stems with calibrations for stem rotation count, for fine adjustment and repeatability.
Disclaimer: I only use these companys products, I do not sell them.
pennpoint
