Extract polylines x,y and length data?
Does any one known how to extract the start and finsh X,y coords and total length data from all polylines in a drawing and save data in .xls format?
I think it can be done through Lisp or VBA routines but don't know how, any help would be great.
Dan
Dan
RE: Extract polylines x,y and length data?
What you want is "doable" through programming but polylines can be complex entities. The start and end points are just two of the possible vertices in a polyline, is that the only points that you are looking for?
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
Yes, I only want the start and end points.
Cheers
Dan
You send me an email and I send you a routine. You want the routine in Visual Lisp or VB?. In both lenguaje can it ;)
Email: eliasunoARROBAhotmail.com
Un saludo de SpeedCAD... :)
CHILE
FORO: http://www.hispacad.com/foro
