fuel/air cycles
fuel/air cycles
hey guys looking for a little help on a little project.
im working from C R Fergusons book 'internal combustion engines' so would be helpful if anyone is familiar with this.
i am trying to thermodynamically model the cycle of a particular engine.
im having a little trouble with the compression, expansion and combustion processes explained in chapter 3.
The book gives a combustion program on p74 called 'equilibrium combustion solver'. You put in pressure, temp, equivalence ratio and fuel type and it gives mole fractions of the products and mixture properties. What im not sure of is whether you put in your properties (p,T) before combustion and it calculates what mixture properties will result after, or whether its for calculating
mixture properties (h,u,s,v) of the combustion products at that specified pressure and temp.
im guessing the latter based on the fact the author also uses the program to calc changes of state due to isentropic compresion or expansion.
any help much appreciated,
thanks,
Gareth.
thanks,
Gareth.
RE: fuel/air cycles
