LEM Voltage Transducers (difficult to use ????)
I have bought the LEM Voltage Transducers LV 25 -P for my experiment. As recommended in the datasheet, I used the RM as 100 Ohm, RM = 26KOhm to measure the voltage of 250V AC. The supply DC voltage is +/- 15VDC.
But the measured voltage at terminal M is always at 15V when V HT is > 0 , and -13.8 V when V HT = 0.
Could you please show me more details of how to use this transducer to measure ? (if possible, pls give me an example circuit)
Thank you very much
Thank you very much
