B737-300 MZFW Increase
I am looking for some document that can increase the Maximum Zero Fuel Weight of the B737-300 from 106,500 lbs to 109,600 lbs.
Can anyone help, if you have the service bulletin number or any informations, let me know.
Thank you.
Thank you.
RE: B737-300 MZFW Increase
If you have any information, let me know.
Thank you.
"Simplicate, and add more lightness" - Bill Stout
Steven Fahey, CET
I am unaware of any physical config change but there may be one.
To get the SB, you pay money.
I do not know of an STC.
If you use an "illegal copy of the SB it will not have an effectivity that matches your aircraft and the FAA T.C.D.S. will not be updated to reflect the change of MZFW of your aircraft, ie. it will not match its certification data and will be officially illegal.
Sorry for the bad news.
