Unhandled Error messages
Hi Gang ...
I've got a problem and I'm hoping that you might be able to help me.
I have "Open referenced documents with read-only access" checked-off for my personal preferences. Now when I open an Assembly or Drawing and then open an associative file, I only have READ ACCESS. So if I want to change that part, I need to RE-LOAD that file. Simple enough, easy to do and self explanatory.
Here's when the trouble starts. When I've made what ever changes I wanted to that file and then try to save and close out of it (and go back to the parent file), SolidWorks crashes and I get the Unhandled Error message.
This happens every time ... it doesn't matter what drawing or assembly file I open first, or what component of that file I open and reload.
Any suggestions on what be happening and why ???
BrianM
BrianM
RE: Unhandled Error messages
2) Have you recently installed or uninstalled anything?
3) Have you checked for viruses, etc lately?
4) Have you rebooted & still have the problem?
5) Do you have any other apps or services runnning?
FAQ559-863
2. No
3. Yes, nightly (according the IT guys here)
4. Yes (first thing I tried - several times)
5. No
Brian Mazejka
Project Engineer
L-com, Inc.
http://www.frontiernet.net/~mlombard/ - Rules of thumb then on to "Trouble shooting a crash prone system"
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
If this is only happening on your machine, try doing a repair from the SW CD's.
Check out Scott's suggestions first though.
FAQ559-863
