Velocity Coefficient
I am looking for a ref. on culvert analysis with approach velocity.  Specifically the cofficient for velocity to reduce the velocity head from the ponded headwater of the culvert.  Hope you can help me, my co-worker and I have been looking through many sources and havent had any luck yet.
RE: Velocity Coefficient
Can you tweak the contraction coefficient?  If it is a pond with negligible velocity into the culvert you could set the contraction coefficient high, like 0.9 or 1.0 (worst case).
A reference could be the Hec-RAS Hydraulics Reference Manual available at:
http://www.hec.usace.army.mil/software/hec-ras/documents/hydref/index.html
Chapter 3 has contraction coefficients (p. 3-20)
FHWA has software to analyze culverts, if needed.
http://www.fhwa.dot.gov/bridge/hydsoft.htm
Hope this helps,
BLT
