Overpressurizing of mechanical seal!!
How is it possible to overpressurized a Mechanical Seal?
When Starting a pump? Turning one out? By starting the third one?
Any help would be appreciated... Thanks
RE: Overpressurizing of mechanical seal!!
If you are suspecting Stuffing box overpressure for premature seal failure, unless something has changed in your application (pump re-rate, product change, line re-rate, mop change, etx) I'd look at and eliminate your usual suspects first.. (flush flow, stuffing box concentricity, stuffing face/shaft runout, etx)
