need to access data from previous time samples
I need to access data from a previous time sample to run the a subfuntion at the current time sample (for example, if x is the parameter then I need access to x(k-10) at time time k). Simulink is not letting me do that. It gives output only after the simulation is complete. Do any of you know if this can be done? This is urgent. please let me know ASAP. Thanks in advance.
RE: need to access data from previous time samples
