Modified PTFE Seat Suitability for CL150/300 Valves
Does anyone have any experience using valves with modified PTFE seats in typical oilfield services that may have some abrasives like sand present? The molecularly enhanced PTFE is simply PTFE that has a small amount (less that 1%)perfluoropropylvinylether (PPVE) added, which has no affect on chemical compatibilty or temperature capability, but does make it a stronger and more durable material than straight PTFE.
I'm looking at this only for lower pressure, CL150 and CL300 valves. We'd really like to use this material for the universal chemical resistance it provides, but there are some on our staff that fear that even the modified PTFE is not durable enough to resist cuts and wear when exposed to sand and other debris that will often be present in common oilfield fluids. The alternatives are some of the special nylons, however we would really have to pay close attention to the process fluid.
Any thoughts or experience from users would be helpful.
RE: Modified PTFE Seat Suitability for CL150/300 Valves
try www.aesvalves.com
