Protective Coating to tanks, nozzles. Is Tnemec a good brand?
Tank contractor propose to use Tnemec for protective coating, anyone use this product before?
1. Surface Preparation:
   a. All interior and exterior weld preparation, grinding, removal of weld flux and splatter to be performed prior to Abrasive blast cleaning
   b. Interior surfaces: SSPC-SP10, 1.5-2.5 mils
   c. Exterior surfaces: SSPC-SP10, 1.5-2.5 mils
2. Coating Application:
   a. All Carbon Steel interior surfaces (except interior of any piping) to receive a 2 coat Tnemec system.
       1. Prime: Beige @ 4-6 mils dft.
       2. Finish: White @4-6 mils dft.
       3. Total exterior system of 8 mils dry film thickness.
   b. All Carbon Steel exterior surfaces to receive one coat Tnemec epoxy. All exterior extrusions; ladder, man ways, nozzles, etc. will receive 1 finish coat of Series 10-75 Endura-Shield Urethan.
       1. Prime with Series 20 or FC20 Pota Poz @ 4-6 mils dft/coat, with special attention to hard to cover areas.
       2. Finish extruding appurtenances with one coat Series 10-75 "color to selected by owner" @2.5-3.5 mils dry film thickness.
=====>>> Do you have any experience with Tnemec, does this application look unbiased to any of you? which color for appurtenances to match with the tank, white/beige?
Thank you for your time!
RE: Protective Coating to tanks, nozzles. Is Tnemec a good brand?
Thank you for the chart!
Wonder if 2 coating for thermal storage is enough? Product Temperature is between 40-54F Chilled Water System.
