Flow meter for Soap Foam
Greetings fellow engineers,
Does anyone have experience with the flow of soap foam with the consistency of shaving cream?  What type of mass and/or volumetric flow indication did you use?  Did you use a 4-20A signal to track this data?
Scott
RE: Flow meter for Soap Foam
you need to define your fluid proprerties (density viscosity), pressure, temperature, flow rate, basis for measurement (mass or volumetric), pipe size, how is it moved(pumped), etc...
