japanese steel tube specs
Extremely hard to find supplier in the US. I have to find DOM tubing as follows:
15.0 mm O.D., 2.25 mm wall, meets Japanese standard
STAM290GA or STAM35G-M.
U.S. suppliers I have contacted don't understand the spec numbers listed.
RE: japanese steel tube specs
http://www.google.com/search?hl=en&lr=&ie=UTF-8&oe=UTF-...
I've found one good way to get specs is to ask your customer for a copy of the spec that they want you to use, Theres usually a copy w/ the buyer or QA manager.
There is likely a reference for the conversion I dont know where it is thou.
You can go to this website for American Spec. and convert if you can get a listing of the Japanese Spec.
http://www.copperweld.com/pdfs/DOMSpecs.pdf
Good luck Specs from different countries are hard.
Nick
I love materials science!
http://www.copperweld.com/locations4.htm
http://www.hoovers.com/seymour-tubing/--ID__115443--/fr...
Brad
