Remote starter design
Hi All -
I'm thinking about designing and building a remote car starter. I know that there are lots of different ones already out there in the market, but where's the fun and learning in going off-the-shelf ?
Most starters use relays, either external triggered from a smaller one inside, or they have larger ones internal to their box. What about using mosfets instead ? It would be nice to have be completely solid-state, no moving parts to fail.
Dean.
Dean.
RE: Remote starter design
While you're brainstorming, I've got more and more applications these days for continuous solenoids...so if you could add this feature into the mix, I'd appreciate it. Dave
1) Put on handbrake
2) Push button x on remote
3) Remove keys (car keeps running)
4) Get out of car, close door
5) Push button y on remote
Step 2 tells it that you're stopping the car, so turning the keys to off and removing them doesn't actually stop the engine. Step 5 actually stops the engine, and possibly arms the alarm.
Now the system knows that the car is in neutral, with handbrake on, so is safe to remote-start.
I'm thinking about possibly paralleling up several heavy-duty mosfets to handle the current surge of the engine start. Any ideas ?
Dean.
one technique i have seen used with diodes is a small resistor on each with the resistors forcing the current split, not the best solution in the world but it worked well in that specific application.
does anyone know how much current a car draws, minus starter moter but including starter relay?
Its cool to think out of the box, but I would think a mechanical relay for this type of use would be alot more reliable and easier to change/diagnos. just my 2 cents
In my experience with some home made (by electrical engineering students that were fairly competent) high current motor drivers i've seen parts of mosfet circuits fail causing a significant amount of current to leak through the transisitor. This could be a bit unfortunate in your case. If you can, however, build a more bulletproof circuit than this or provide some sort of failsafe, it could work.
Greg
Big time wrong on that one...they can, and do fail while on. The easiest one is a relay that connects circuit A in one direction, and circuit B in the other...in that case, no matter what direction it fails in, it's an unintended and potentially bad thing.
Another possibility, though, is the contacts arc and weld themselves together...once welded together, it doesn't matter what happens with the coil, it's going to stay closed.
Absolutely do NOT count on mechanics or software to be foolproof every time...the moment you make an item foolproof, someone goes and makes a better fool.
Current splitting with power transistors is usually done by inserting a resistor in each emitter lead, chosen to give about 0.2V drop at running current. As you said, without this one transistor will steal most of the current and overheat.
