Finding Center of Gravity
How do I find center of gravity of an assembly in UNGX2?
Thanks in advance!
RE: Finding Center of Gravity
I'm using NX, but the method should be the same (assuming menu items have not moved).
Analysis -> Mass using solids... then pick the solid bodies that make up your assembly (you can pick up to 1000 at once). The resulting listing will show you the center of gravity and other information.
Make sure the bodies have the correct densities assigned to them.
