Revision vs. New Part Number?
I would like to get the group's input on the rules governing revising a part vs. issuing a new part number.
As I understand it a part gets a revision level increment if the part is interchangeable (form/fit/function). When the part/assembly is not interchangeable it gets a new part number.
Louis
RE: Revision vs. New Part Number?
Here a part/assembly gets a revision level increment if the part is interchangeable & backwards compatible. If this is not true it gets a new number.
Alex
I agree with alexit, the parts has to be backwards compatible as well as meet fit/form/function requirements to only get a revision change.  If it's not backward compatible or does not meet F3, it should get a new part number.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Thanks. That is what I thought, I just needed confirmation.
