friction factor of steel rubbing against steel
Friends,
I need help. I'm trying to calcualte
the amount of force required to overcome
the hinge friction on a
36" wide x 84" high x 1-3/4" thick steel door
weighing 141 lbs. I have calculated
the torque created by air pressure differential
and have worked out the door closer effects.
What I really need is a friction factor
of steel rubbing against steel at the hinge.
This question is in relation to
ADA act of 1990
The Americans with Disabilities Act of 1990 section 4.13.11 reads as follows:
(b) interior hinged doors: 5 lbf (22.2N) 22.2 newtons .
ADA act of 1990
RE: friction factor of steel rubbing against steel
Badly rusted and pitted surfaces rubing on each other can get up to .8 to 1
