Toolbars not being saved on exit. UG NX
I have a problem that my toolbars are not being saved when I exit UG NX. I have searched the ug_english and ug_env files but have not seen anything there to help.
This problem is becoming pretty hard to deal with. Please help.
Dave
Dave
RE: Toolbars not being saved on exit. UG NX
Is the box for Save layout at exit checked?
My is and V18 doesn't save my settings, either. I also have admin rights on W2K. Old W2K system worked fine. Both IBM Z-Pro's, just newer one.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
This one have really got me.
I have the same problem on a Win2K box running UG NX2 with local "poweruser" privledges. An identically built box, software, and permissions at home, works fine.
-Dave
http://www.moslerauto.com
Dave
Check PR-04703205 , it has a solution, but its different than I recall.
-Dave
-Dave
CLICK ON THE FIRST RADIO BUTTON 'SAVE LAYOUT AT EXIT'
YOU MUST BE IN NAVTIVE UG - IF YOU ARE IN IMAN THE SETTINGS SOMETIMES DON'T GET SAVED.
WHEN YOU HAVE SET UP THE ICONS TO YOUR LIKING MAKE SURE YOU TOGGLE THE RADIO BUTTON 'OFF'.
quick question some of you users may have already tackled.
does anyone have a process to create :
good quality drawing output in .TIF format .. to scale, or at least a consistent scale. I need this output to support a further data management package.
your thoughts..
best regards........ Gary
Aren't you using v18.0.4.2 on a Win2k machine? These folks are having a problem with NX2 on an XP. I suspect there may be some differences.
