Involute Spline creation
I need to generate a true involute spline using AutoCad R14. The form must be correct so a tool layout can be produced. This layout will be used to dress the form on a grinding wheel to produce the cutting tool. I have tried the Machinery's Hand Book method utilizing the base circle, tangent line, and arc length, but can not correlate that to the true size of the tooth profile.
RE: Involute Spline creation
You could try creating a parametric curve.
None-the-less there are several programs that will draw an involute gear tooth. One used in solids is GearTrax by Camnetics, Inc.
