Diameter symbol
Diameter symbol
Diameter symbol
In previous versions of cad to obtain engineering diameter symbol I just had to type %%. Just moved over to 2004 and it doesn't work.I am using Architectural and in the symbol selection in the tolerance tag the required symbol is not there.Any help would be much appreciated.
RE: Diameter symbol
ADT2004, Arial: %%c
or (for DORU ) alt+ 0216
Lothar
RE: Diameter symbol
Unicode is
\U+2205
This is not a key combination just type what is shown above.
RE: Diameter symbol
As stated above %%d before the value when you are in text,dtext or mtext; alternate method is when in dtext or mtext,right click in the text box, select symbols, and character map will show, select greek font, pick the phi symbol, copy to clipboard, go back to the text box, right again, select paste(from clipboard) and symbol will show up in the text box, then type value and ok it.
RE: Diameter symbol
Ø = alt + 0216
° = alt + 0176
± = alt + 241
These all work for me when I'm in any text editor in AutoCAD. Just like everything else in CAD, there's more than one way to get what you want.
