Processors for AutoCad 2004
I am looking to purchase a laptop to run AutoCad 2004 and also Revit 6,however I am on a budget of less than £1000 (which includes the VAT).
I am confused with Celeron, Athelon, Centrino in comparison with a true Pentium 4 processor.
We have pentium 4 1.5 Ghz machines in work which handle AutoCad quite well but also a Pentium Celeron 2.2Ghz that struggles with AutoCad which leads me to believe that this is a cut down version of the pentium processor.
Does anyone have any good advise or better still point me in the direction of an article comparing processors.
Welshman
Welshman
RE: Processors for AutoCad 2004
You can start from here http://www20.tomshardware.com
The fact that your Celeron 2.2Ghz struggles with Autocad is not a consequence of Autocad's needs. You should take your time to "clean" and re-arrange a little bit that computer.
As far as I know the latest versions of Autocad should work well on any processor faster than 1.0 GHz
http://computer.howstuffworks.com/question268.htm
"Whether you think that you can, or that you can't, you are usually right "
.. Henry Ford
Heck, the Athlon64/Opteron processors are probably the fastest AutoCAD processors out there. I know they are for Solidworks but haven't looked to hard lately for ACAD as I don't use it much anymore.
