Wanted axial fan with large flow
I'm looking for the axial fan, which can supply a large flow rate of around 20-100m^3/s. The pressure requirement is not very important in my case as we are interested at the pressure loss across an elbow drafttube model and a large flow will give a better result. Any one has come across some cheap axial fan with large flow rate?
Please kindly leave me some contact or reference website.
Thank you,
Danard
Thank you,
Danard
RE: Wanted axial fan with large flow
Also contact any of your local cooling tower manufacturers.
100m^3/s is not a big fan for a cooling tower. You may be able to buy a secondhand fan from them.
Cheers
Steve McKenzie
