Modicon 3240 & Wyse -185ES communcation
I need to connect a Modicon 3240 controller to a Wyse-185ES monitor and keypad. I cannot locate any documents on the 3240 to get me started. Has someone else done this? Can anyone help?
RE: Modicon 3240 & Wyse -185ES communcation
The 3240, you could as an "interem" step, use a PC's com port and "hyper terminal" to access it, this should be a normal cable, and in hyper-term you can "knock on the 3420's door" with 3 taps of the "enter" key (a general "are you there" request in serial connections).
Or are they using other style coneections for these ?
Greg,
Called "Mr. Fusion" by the Locals :)
