Capacitor Info Needed
Our electrical engineer is a digital guy, knows nothing about start and run capacitors. The caps we need to specify and purchase are:
270-324 MFD @ 330 VAC
216-259 MFD @ 330 VAC
130-154 MFD @ 330 VAC
30 microF, 35 microF, and 45 microF all at @ 370 VAC
and others also.
Question 1 - What are the items to look for in terms of quality, durability, etc. We see plastic cases, metal cases, larger and smaller, but no other information seems to be available.
Question 2 - Where can we purchase these in volumes of 50 at a time?
Would appreciate the help much.
and others also.
PUMPDESIGNER
RE: Capacitor Info Needed
We are building start systems with run capacitors for single phase submersible motors, 2 hp through 15 hp.
PUMPDESIGNER
Might contact firms like
www.aerovox.com
www.comsprague.com
www.cornell-dubilier.com
for suggested vendors.
Thank you.
PUMPDESIGNER
www.evox-rifa.com
I have found their products to perform well in some demanding applications.
Do it right, or don't do it at all.
http://www.thomasregister.com
and type Capacitors: Motor Start under Product or Service, which will return 23 companies to approach to
///Mean Time Between Failure (MTBF), Life-Expectancy, Life-Cycle, etc.\\\
///These are more technological aspects linked to manufacturing, material science, etc. Answers may be proprietary to some extent.\\\
///Visit the Thomas Register link that I posted above, and other links posted above.\\\
Tried that link, no worky.
Tried obvious word combinations of evox riva on Google, no return.
PUMPDESIGNER
This was copied out of my browser address bar:
http://www.evox-rifa.com/index.php
Sorry for missing the http:// off the front end.
http://www.abb.com/us
"Venditori de oleum-vipera non vigere excordis populi"
