FRACTIONAL HP MOTOR WIRING
This should be easy for a EE, not so simple for a ME like me. I am restoring an old 1/3 Hp, 110/220V Delco motor. I will be using it as 110V. There are 4 wires, 2-red, 2-blk. Which wires do I connect? The brush assembly has an adjustment which rotates the whole brush assembly. Is this motor reversible? The tag has no direction specified. Thanks for your help.
RE: FRACTIONAL HP MOTOR WIRING
Please write all the name plate data.
As for its's connection, it sounds as if it has been rewound!
Which pairs have continuity?
Can you disassemble the motor and descibe what wires go to what and the ohms of each pair and if all the leads have continuity to each other?
