Swamee & Jain Friction Factor Equation
The original Swamee & Jain explicit equation for friction factor calculation for turbulent flow in pipes has f = 0.25/[(log.....)]^2.
I have also seen on the web f = 1.325/[(log.....)]^2. The difference is NOT the factor of four beween the Fanning friction factor and the Darcy friction factor. Can anyone explain the discrepancy?
RE: Swamee & Jain Friction Factor Equation
never seen the 1.325, but the 0.25 is the one I memorised after checking it against Shacham and Colebrook White with good correlation.
I expect it may be a mistake.
If you are from Perth Australia, you probably got Swamee Jain 0.25 from the Hardie Iplex PE manual. Where did the 1.325 come from?
Cheers
Steve McKenzie
Id est,
Thus, one formula is based on log x, and the other on ln x.
Would I be right ?
Yes, you're correct - I have gone back and checked the two articles using 1.325 in the formula and they DO use ln rather than log. Thanks for spotting the difference.
Eng-Tips.com : Solving your problems before you get them.
"Things should be made as simple as possible, but not any simpler." Albert Einstein
