View on a face
View on a face
View on a face
Again  This is related to my other post
Is there any way I view a face of a 3d component , I had to rotate it then wanted it back so I could view the top face , but its slightly off, how can I view the top face square on
I am sorry I do have the big book in front of me ,, but a chocolate teapot might be more help
King regards Stephen
RE: View on a face
Have you tried multiple viewports in paper space?  Change UCSFOLLOW to 0 once you have rotated each viewport as you like it.
RE: View on a face
yes I am afraid I have its getting the model square that the prob
ie so I look straight down on a face
is there a view on face command?? I am loathed to redraw this drawing but there are so many odd things it might save time!! to do so
thank you for your reply
All the best stephen
RE: View on a face
On your "ucs" toolbar, there is a "face ucs" button (6th button over in ACAD 2K).  You might also want to try "3 point ucs" (10th button over).  After setting the ucs, use the "plan" command and hit enter.
Flores
RE: View on a face
Thank you ,it was the Ucs worked fine also cured the disappearing view of mensioned in the last post ..Thank you
Stephen
