3D drawing problem
3D drawing problem
Sorry folks
But I have a strange thing happening, I drew a componet in 3d , then What I do in layout I use soldraw etc. But when I am in model space and execute a view comand such as rotate or 3d view The object disappears and becomes a microscopic dot the the void known as model space
I can find it again either by undo , or zoom dynamic untill I see a dot move
Ive tried setting limits and grid any one know what I have done wrong or what I have done
Ive tried copying to a new drawing but still the same thing happens
Kind regards Stephen
RE: 3D drawing problem
have fun Robb
Check that the system variable UCSFOLLOW (type this name on the command line) is set to 1 inside the viewport.
Good luck
Fine Then
then type r to remove the small dot you see
then do a erase
previous
them zoom extent
Please fell free to sen me your drawing to k281969@hotmail.com
Pardal
First I set the ucs to view a face then looked for small dots
As I have been drawing Some how I had made one view microscopic
and yes I saw the dot move
Thanks all once again
Stephen
