Broken Strands
Broken Strands
Background:
-Cast in-situ viaduct, spans ~42m
-3 webs
-6 anchorage in a web
-31 strands in an anchorage
(all fixed at one end, ~12mm dia. each)
-Day 1, stress to 50% design stress for all anchorages
-Day 2, 5 strands in an anchorage were broken while stressing
Any suggestions to this issue?
What the redundancy in strands design(ie 20% or 40%) usually?
What are the measures to rectify the situation?
-3 webs
RE: Broken Strands
I guess you have to de-stress and replace the tendon.
Zambo
RE: Broken Strands
I had a similar disaster to start the year'04. Our fabricator wished me happy new year with the news about a pressure vessel item, designed by me, he was fabricating. At 50% load, during testing, a bolt just snapped into two.
Reason was found later. The guys did not torque this bolt with torque-wrench to specified value, but used their Horse Sense and Hammer. It was over overstressed and taking the load in undue proportion.
Always see that post-tension is applied uniformly and equally. Use Instrumentation, if necessary.
