Defining Restraint in COSMOS
Does anyone know how to create a point restraint (or force point) in COSMOS? Imagine there is a bar of circular cross section. And I just want to fix the center of the circle. Or How I can apply a tension force just to center point of the circle?
RE: Defining Restraint in COSMOS
Shaunzam,
The thing is that you can create point loads and restraints however they have to placed on a vertex of the model.  What it sounds like to me is that you want to load a center of a hole and the problem with that is that there is no mesh at the center of the hole.
What you could try is creating a point in the desired place (center of the hole) and then selecting the inside face of the hole and applying a remote load using that point at focal point of the load.
Hope that gives you some ideas.
Jon
jgbena@yahoo.com
I found out the answer and that would be creating split lines and choose the vertex. Thanks Jon though:)
Shaun
Yeah that was where I was going next.. but it sounded to me like you wanted a point out in the air.. in which case a remote load will work well!
Happy hunting!
Jon
jgbena@yahoo.com
