2024-T3 Drawn Tube AMS 4086/WWW-T-700/3
1. Do we need to get the specification from Global
Engineerig or is it avilable on the web?
2. Any ideas on a supplier for Initial Outside Diameter of
3.75 inch X Wall thickness .375-.5 inch?
3. I first went to FAQ's but not much help also tried
Google > Online metals etc.
Thanks in adance.
Leonard
Thanks in adance.
Leonard
Jesus is THE life,
Leonard
RE: 2024-T3 Drawn Tube AMS 4086/WWW-T-700/3
First, I could not find WWW-T-700 on the government standard website (http://assist1.daps.dla.mil/quicksearch/). You will need to order SAE AMS 4086 either from Global or from SAE.
Second, the following distributors supply 2024-T3 Al tubing that meets SAE AMS 4086:
http://www.futuremetals.com/index.htm
http://www.principalmetals.com/prime/result.asp?Family=...
http://www.diversifiedmetals.net/products/aluminum.htm
I am not sure who manufactures this tubing. I tried Alcoa, but they only seem to do 6xxx series as standard. Kaiser probably makes this out of the Chandler, AZ facility.
