Symbol Creation
Symbol Creation
1)Is it possible to create our own symbols in SW?.& use it in drawing
2)In drawing why we cant attach any thing like notes,balloons to Planes
3)The Blocks cannot be attached to any thing in drawing view
Plz help as i need these info's reg my project assignment.
Senthil Kumar.E (B.E Mechanical)
senthile@geometricsoftware.com
RE: Symbol Creation
You can attach a Note to a view, by "locking view focus" or if you don't have that option checked then you can just double click the view.
Nope blocks can't be attached to anything in a drawing (As far as I know)
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
RE: Symbol Creation
Anyone who opens your drawing will require the same character map file. The character definitions do not get embedded in the file.
If you want to represent a plane in a drawing, try sketching curves and making them coincident or collinear with the plane to represent the plane if it is in section. If the plane is not viewed edge-on, perhaps a construction sketch of a rectangle or a planar surface body on that plane in the model.
http://www.EsoxRepublic.com
RE: Symbol Creation
2) Because drawings are flat, 2D beings. They dont have planes. You may be able to see them in the Drawing View Manager but they serve no real use in the drawing view.
3) If you activate the block's "leader", the arrow can be attached to parts of the drawing view & will force the block to move with the view.
Does this help?
FAQ559-863
RE: Symbol Creation
I hear in SW2005 you can add symbols to notes on dwgs.
eg Finish symbol to dwg notes.
RE: Symbol Creation
The file contains instructions for creating symbols and symbol libaries.
Be careful! Create a backup of the original file. If SW don't start after editing the file, it's because you have a sintax error in it.
Lots of trial and error before you get a symbol that looks good.
RE: Symbol Creation
Today ive got a SW SP2.1 installed . In that i was able to attach block to edges of my parts in drawing view. This attached block gets updated if I alter some distance in my part file.
SBaugh
can u tell me exactly how to create the symbols in SW
RE: Symbol Creation
You can now drag blocks, not only by their base points, but also by points of sketches within blocks. The points inference and snap to other points in the following ways: block-to-block, block-to-sketch, sketch-to-block, and sketch-to-sketch. For example, you can drag a block by the vertex of a rectangle inside the block and snap to the end point of sketched line on the drawing sheet or in another block. The snaps do not create relations, so you can drag the entities apart.
RE: Symbol Creation
Scott Baugh, CSWP
FAQ731-376
RE: Symbol Creation
John Richards Sr. Mech. Engr.
Rockwell Collins Flight Dynamics
A hobbit's lifestyle sounds rather pleasant...... it's the hairy feet that turn me off.
