Importing STEP file error
Right then. I have imported a stamped metal surface STEP file. In the feature manager there is a little error logo on the Surface-import step telling me that it is not happy. As a result, I can't do anything modifications other than delete a few of the surfaces. When I try anything else, I keep getting:
Surface-Imported1: Warning: Imported geometry has 3 Check entity error(s)
Is there something that I can do differently so that there are no errors because I can't find the errors.
Paul.
Paul.
RE: Importing STEP file error
Right click imported geometry and choose Diagnosis -> Faces -> Diagnose & than you can fix or remove bad faces.
Scott Baugh, CSWP
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
I do this sometimes. Usually the offending surfaces are lends (spherical portions are a nuisance). These aren't difficult to replace. Patch works well for this.
http://www.EsoxRepublic.com
