Caspian oil piplines constuction and fluid dynamics
What is the size of pipe with length and diameter of some of the proposed pipeline routes? Also, what would the approxiamte cost and type of pipe used? Could we calcualte headloss for a route, and if so how? What are the numbers on gates and bends on such a project?
RE: Caspian oil piplines constuction and fluid dynamics
However for a complete analysis, you would be advised to employ a transient analysis tool which would provide a detailed pipeline pressure profile, liquid handling characteristic and other peretinent information for optimising the pipeline and designing the downstream reception facility.
I work for a specialist company that provides engineering services for the design and installation of marine pipelines, not only for oil and gas applications but also for demanding special design considerations such as high pressure, high temperature, deepwater, arctic service or aggresive fluids. Our experience includes a number of pipeline design projects in the Caspian Sea.
If you require further technical assistance for flow assurance and design of your pipeline, you may e-mail me at:
emmanuel.adesioye@intec-delft.com.
<http://www.pipedir.com/>
Pipes & Pipelines International
"Regularly read by over 3000 decision makers in the pipeline industry world-wide, Pipes & Pipelines International, is the ONLY UK specialist publication dealing specifically with pipelines for the oil, gas, products, water, sewage etc., industries."
Paul
___________________________________________________
Web-Based Resource for Process Piping Professionals
Mailing List: <http://www.egroups.com/group/PipingDesign>
Webpage: <http://www.PipingDesign.com>
