Reverse lookup?
Reverse lookup?
Reverse lookup?
I have a list of (hundreds of) colors with the numbers we have assigned to them such as:
100n     Light red
101n     metallic blue
102n     transparent red
I created a lookup so that a user can type in a number to see what color it is assigned. I would now like to be able to type in a base color such as "red" and get a list of all possible color numbers (light red, met. red, bright red, etc, etc).
Is there a built in function(s) that I can use to do this? I am fairly comfortable writing VBA code, but I don't want to reinvent the wheel (unless of course there are lots of value added features and high margins - oops got caught up in the marketing spirit).
RE: Reverse lookup?
A pivot table would allow the data association to be reversed...
TTFN
RE: Reverse lookup?
IRstuff,
Thank you for your post. However, after looking through the help files and experimenting with a pivot table, I am unable to get the result that I would like. Assume the numbers are in column A and the descriptions are in column B. If the user types "red" into the input cell, I would like a list of all entries that have "red" somewhere in the description (say numbers in col C and descriptions in col D).
Thank you for the idea, pivot tables are new to me so it is quite possible that I am using it incorrectly. I will dig a little deeper into the help files to learn what I can. In the mean time any and all ideas are welcome!
RE: Reverse lookup?
Will the autofilter function work?
RE: Reverse lookup?
Make a data base with numbers (column A) and colors (column B).
Highlight complete database and select Data/AutoFilter.
Dropdown arrows appear in each column.
Select the one on color and then select custom.
In box select equals to and then in the box to the right  type either * red or red * depending on what you want sorted.
Alternately select ends with or begins with and then type red in second box.
RE: Reverse lookup?
Thank you melone and aviat! It works wonderfully. Stars for both of you.
