Stiffness matrix for bearings
Hello.
I'm looking for the stifness matrix (5x5) of the 6014 and the 1014 bearings.
Even the load deflection curve for these bearings would be useful.
Please, could you help me?
Thank you!
Thank you!
RE: Stiffness matrix for bearings
Do you need the experimental stiffness matrix or simulated ?
Dietl, P. Damping and Stiffness Characteristics of Rolling Element Bearings,Theory and Experiments. PhD Thesis, Mechanical Engineering, Technical
University of Vienna, 1997.
For simulated stiffness matrix: I can generate from my own code.
Stiffness matrix can be generated for dry contact ball bearings whereas both stiffness and damping matrices for lubricated ball bearings.
