Aluminum exposed to Air with Citric Acid Fumes
Anyone know how Aluminum will do when exposed to citric acid fumes?
I'm working on a project where we were using 304LSS or 316LSS and now it looks like we might have to go with Aluminum.  The problem is the corrosiveness factor.
I really don't know if either of the SS are good for citric acid fumes either but hope that you experts can help.
Thanks.
RE: Aluminum exposed to Air with Citric Acid Fumes
Forgot to mention that the standard grade of Aluminum we use is 1100 AL.
