Averaging in Execl
Averaging in Execl
When using Quattro Pro, I can use a function "PureAverage" to average a series, even if some cells of the series contain unsatisfied formulas. "PureAverage" ignors these cells and averages the remaining cell values. Does Excel have a similar function??
Steve Wagner
Stiffler, McGraw & Assoc.
Hollidaysburg PA
Steve Wagner
Hollidaysburg PA
RE: Averaging in Execl
good luck!
-pmover
I think :)
Thanks!!!
Steve
1 1
4 1
5 5
6 1
7 7
8 1
9 9
10 1
average 3.222222222
count 9
sum 29
TTFN
Steve
If your friend uses the COUNT function, it ignores the blank cells, so the fact that you added a bunch of zeros is irrelevant. The only reason it's screwing up is because your friend is explicitly defining the number of items to average.
TTFN
It seems to come down to the fact that Quattro treats blank cells as blank (and won't complete a calculation) while Excel treats blank cells as zero.
Sometimes the data actually is a zero, so checking for zero won't work.
Steve
=SUM(A1:A7)/COUNTIF(A1:A7,">0")
Where ALL data (including 0's) is in cells A1 to A7
