A nonlinear analysis of polymer hydrogel using ANSYS
Dear all,
I am performing a nonlinear analysis of polymer hydrogel material using ANSYS software 6.1 on UNIX. My model is the follows: a polymer layer is confined between two plates within a closed volume. The upper plate is very flexible and the lower one is a rigid mesh. When this model is immersed in the solution (e.g. water), there is a flow entering the polymer layer through the mesh holes and making it swollen isotropically, consequently causing the deflection of the upper plate. This work is to calculate the stress and strain of polymer hydrogel material due to swelling process and of the upper plate, as well. I don't know which available theoretical basis of ANSYS (Equation and Load of nonlinear materials) should be used for this case. Generally, my knowledge of ANSYS is very poor. Can anyone tell me how to perform this nonlinear analysis using? any reference is also much appreciated.
Thank you beforehand,
Regards.
Regards.
RE: A nonlinear analysis of polymer hydrogel using ANSYS
I am getting difficulties with my problem that I haye to analysis the swelling process of nonlinear material i.e. polymer. Can any body help me? Please give me some suggest.
Thank you beforehands
