UBC 97: Non Destructive Testing In Zone 4
I am looking at Section 1703 of UBC 97 and it states that non-destructive testing is required for all welded, fully restrained connections in primary frames of ordinary moment resisting frames. I am not sure how to interprete this section of the code. Does this apply only to fully welded connections? Or does it also apply to the splice welds in a bolted connection? How has this requirement affected the pre-manufactred steel building industry?
I find it hard to believe that the added cost of non-destructive testing is required of steel building manufacturers. This would significantly alter the price of the buildings. Does anyone know if building officials are enforcing this section of the code?
Thanks in advance for your help.
JS.
JS.
RE: UBC 97: Non Destructive Testing In Zone 4
The ultrasonic tests may be performed in a fabricators shop or in the field by a certified technician.
Building inspectors do enforce this provision of the code. At least they did in southern California around 1990 -
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.
