Hard Particle Bearing Damage
I'm looking at a case hardened pump shaft that also serves as an inner race for a needle bearing. The shaft has hard particle dents all over it and is starting to spall in one spot.
How hard does a particle have to be to dent the surface of a steel shaft with a case hardness of HRC60? I have a potential source of cast iron debris at HRC20-30. Would this be hard enough to cause dents?
Any help would be appreciated.
Thanks.
Thanks.
RE: Hard Particle Bearing Damage
