How to Clone an assembly ?
Hello All,
I need to clone a large assembly, multiple times. When I tried the "Save As" option, ProE opens a table format to edit the names of new parts. Do I have to use "Save As" , everytime I wish to clone the assmebly ?
Or
Is there any option in ProE for MULTI-CLONING the assembly along with all the parts, in ONE GO?
Thank you,
regards,
Jayanthi.
Or
Thank you,
regards,
Jayanthi.
RE: How to Clone an assembly ?
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
I use Pro/Engineer 2000i2
Jayanthi
But if you want to clone only your assembly (sharing the same components) then you can do it in explorer or in DOS window.
-Hora.
