26.4KVA CPT
26.4KVA CPT
26.4KVA CPT
I'm trying to find a manufacturer that can build a single phase CPT with primary windings rated 26.4KV @ 125KV BIL, and a 120/240 secondary.  All I need is 5KVA.  I am planning on putting this CPT in an enclosed piece of metal equipment so a dry type is preferable.
Does anybody have any ideas?
RE: 26.4KVA CPT
What you are looking for is made and about 4 years ago I purchased one for a hydro project. The one that I used was made be General Electric (USA).
RE: 26.4KVA CPT
Thanks.  I do a good deal of business with GE. They purchased ITI (a small CT and PT manufacturer in Florida) to handle switchgear style PTs and CPT's.  They do offer a product I can use, however it is much larger than I need, and it costs too much.  I'm hoping to find a smaller manufacturer who can do exactly what I want...  I've located one company called AFP Transformers that can manufacture what I want.  But they are the only ones so far.
RE: 26.4KVA CPT
What you basically need is a 25 kV VT with a thermal burden of 5 kVA. You might want to try to contact Ritz. They make dry-type VTs at 25 kV and they may be able to design a special one with a 5 kVA thermal burden.
RE: 26.4KVA CPT
Suggestion: Visit
http://www.thomasregister.com
and type Transformers: Custom under Product or Service, which will return 218 companies to approach to
