Inserting Multiple Blocks
Hi all,
I am working with 200+ tiled city maps featuring CATV layouts. My problem is that if I create a composite map of the entire city the file size gets very large. What I am doing instead is dividing the city into manageable sections. Is there a way of multiple inserting all the background maps without having to call up each map individually?
Rgds
AnFearDearg
RE: Inserting Multiple Blocks
Designcenter?
Lothar
Use xrefs rather than insert? You only have to "call them up" on the first setup.
