the problem of installing abaqus 6.4
ABAQUS/Viewer
         ...ERROR
            ABAQUS did not complete successfully.
            Please see Viewer.log for details.
            Turning off hardware acceleration may correct the
            problem. See ABAQUS Online Support System Answer
            1249 for details.
         Continuing...
ABAQUS/CAE
         ...ERROR
            Please see CAE.log for details.
            1249 for details.
         Continuing...
viewer.log:
<98 out of 99 licenses remain available>.
FXGLContextEx::create(): wglCreateContext() failed.
ABAQUS Error: ABAQUS/CAE Kernel exited with an error.
i have turned off the hardware acceleration in the graphicsconfig.env,
what is the problem?
thanks!
RE: the problem of installing abaqus 6.4
A workaround is to set the environment variable ABAQUS_KERNEL_VIEWPORT in your C:\ABAQUS\v6.4-1\site\abaqus_v6.env environment file. Edit this file and add the following 2 lines:
import os
os.environ['ABAQUS_KERNEL_VIEWPORT']=ON
/karelin
first thank karelin!
but,i still donot solve the problem,
i added the lines,but the cue:
            1249 for details.
still exist!
expect your help!
thanks
Did you ever solve this problem?  I'm having the same problems even after doing the hardware acceleration and 2 lines trick, ABAQUS/CAE and ABAQUS/Viewer have errors durring verification.
Thanks.
