Indirect sink waste plumbing retrofit
Does anyone know of a Mfr that makes a simple retrofit assembly that would allow me to turn a commercial kitchen sink that's plumbed directly to the sanitary sewer system into an indirect connection?  This is a remote remodel and I don't want to cut up the floor in order to install a floor sink (or similar) under the sink.  What I'm looking for would be similar to an indirect waste for a backflow preventer (example) only made for under sink installations.  Or perhaps a floor sink that's made for above ground installations that would fit under the normal sink waste lines.
Thanks for the help or leads.
RE: Indirect sink waste plumbing retrofit
Hi Russ,
It has been a while since we last talked.
Do you have enough room for a funnel drain?  This may work provided the sink does not have a cabinet under it.  Seem to me there is a requirement for indirect drains to be placed in a well-lit, well-ventilated area readily accessible for inspection and cleaning.
